flywheel remover
Old Jul 28, 2001 | 01:43 PM
Akira-R's Avatar
Default flywheel remover
Sorry if this is a dumb question but.........
How do you remove the bolts from the flywheel?
Do i need to use some sort of wrench on the crank to keep it from moving?
If anyone has an easy wya of doing it, I'd love to hear it!
thnx,
--reid
Old Jul 28, 2001 | 02:38 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: flywheel remover (Akira-R)
air gun.
Old Jul 28, 2001 | 03:29 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
air gun is the easyest and fastest.
You can also use a large flat head screw driver and wedge it between the teeth on the flywheel and the engine block.
You will need help with this method.
George
Old Jul 28, 2001 | 06:04 PM
accordking's Avatar
Default Re: flywheel remover (Spaceball the lunch box)
The easiest way without using any air tools is as follows:
Use a half in drive(prefered) rachet with a 19mm b series 17 for d series.
Install the rachet on the pulley bolt with the handle of the rachet resting on the chassis(to prevent the crank from spinning.
Then, remove the flywheel bolts.
Old Jul 28, 2001 | 06:57 PM
Akira-R's Avatar
Default Re: flywheel remover (accordking)
Cool, thnx guys.
I used the method accord king suggested, as i have no access to an impact gun or air tools.
The only diff is that the engine is out so i used the ground to hold the breaker bar in place while I broke the bolts off.
thnx again!
--reid
Old Jul 29, 2001 | 04:43 AM
civicguy's Avatar
there is a tool that looks like pliers,it goes atach to the theths iin the flywheel,thats how i did it,cost no more than 10.00 dollars
sorry about my spelling
Schultzie
Jan 16, 2008 09:41 AM
freshly boosted DOHC ZC
Jun 10, 2007 05:51 PM
92integraVTECgsr
Apr 26, 2006 05:48 PM
FUP23
Feb 17, 2002 03:33 PM
Akira-R
Jul 29, 2001 12:00 PM
