Best spot for water temp sender?
Old Jul 18, 2001 | 08:21 PM
Speed PHreak's Avatar
Default Best spot for water temp sender?
Eh? I dunno where to stick this dang thing. I've got an Autometer mechanical bulb to place. I dunno where I should tap it in at. I'm not looking to have t spen any more moeny on these damn guages as it is.......ugh. Whats the 2-pronged sensor under the intake manifold, it looks like it goes into the water jacket, could I tap it in there?
confused.
~steven
Old Jul 19, 2001 | 02:54 AM
sgT's Avatar
sgT
Default Re: Best spot for water temp sender? (Speed PHreak)
upper water pipe under the distributor is a good place.
Old Jul 19, 2001 | 02:01 PM
KekeK_5G's Avatar
you should be able to tap into the factory water temp sender. its a single wire sensor.
Old Jul 20, 2001 | 03:14 AM
LSIntegra94's Avatar
New User
Default Re: Best spot for water temp sender? (1flySi)
Really, the factory sensor? I wouldn't think that the factory sender would work with an aftermarket gauge. My thought would be that the gauge calibration is different, but it would make things easier.
Old Jul 20, 2001 | 05:10 AM
Crack Monkey's Avatar
Default Re: Best spot for water temp sender? (LSIntegra94)
Don't use the factory wire - you don't know how well calibrated it is.
Old Jul 20, 2001 | 11:36 AM
Backmarker's Avatar
If you are using the mechanical sender, your best bet is probably going to be to put it inline with your upper radiator hose.
Heres what I did:
Go to Home Depot and get a 3/4" by 3/4" by3/4" brass tee.
The autometer gause is going to go into the middle connector.
Grind/polish the inside of the T out to improve water flow.
Grind the outside "lip" of the T down to make it easier to get the ends of the radiator hose over it.
Now cut the radiator hose in half about 4" from the radiator
Slip the ends of the hose over the ends of the T
Install the sender into the T using Honda-bond, teflon tape, etc. to seal it.
Use small hose clamps to hold the end of the hose onto the T
That's it - I hope that helps. -Phillip
Old Jul 20, 2001 | 11:49 AM
johng's Avatar
Default Re: Best spot for water temp sender? (ITR_Hybrid)
Got a picture of that you can post? Sounds simple enough.
Old Jul 20, 2001 | 12:50 PM
I founf a better spot, less visable too. I"m gonna tee into the coolant line for the throttle body. I bought a 3/4" T. I also bought 2 nipples to adapt either end to the 1/4" hose size. I can screw the Autometer equipment into the thrid hole in the T. It won't read the temp as quick as it would in the radiator hose, but it'll give me more line to work with
~steven
SurferDude905
Apr 17, 2009 10:07 AM
TypeR15
Feb 24, 2004 12:29 PM
JT
May 4, 2003 07:57 PM
ten_30
Oct 2, 2002 11:08 AM
evo
Apr 18, 2002 02:49 AM
