knock sensor problem
Old Jul 30, 2001 | 06:59 AM
tysir's Avatar
New User
Default knock sensor problem
can a bad knock sensor cause your rpm to tweak up and down when the car is warm up.
Old Jul 30, 2001 | 10:38 AM
eg6ajk's Avatar
Default Re: knock sensor problem (tysir)
nope, when the ecu can't find the knock sensor you will get a code + the ecu goes into safe mode, running rich and with less advanced timing and fuel maps
idling can easily go out of tune becuase: a IAC (rear of the manifold) and sticking plate on the TB, MAP sensor, 02 sensor and vacumm leaks, other thing to check are coolant level and air bubbles..
Old Jul 31, 2001 | 06:52 PM
tysir's Avatar
New User
Default Re: knock sensor problem (eg6ajk)
knock sensor is still trippen. first i thought that the knock sensor was bad so i purchase a 94 ls. that wasnt the problem. i adjusted my distrubutor cap back to normal and still that was nt the problem. there are three sensors on the back of the motor two of them has single wires and one has 2 wires which is which. now with this out of mind what next can i do to find this problem. please help
f22b2
Aug 18, 2017 10:40 AM
SuperBowser707
Dec 4, 2012 07:49 AM
but
Sep 29, 2006 05:22 AM
Blind762
May 1, 2006 02:39 AM
CandyRedHatch
May 5, 2003 08:31 AM
