Wiring Aftermarket Coil
Old Jul 23, 2001 | 06:17 AM
AMSOIL89LXi's Avatar
New User
Default Wiring Aftermarket Coil
How do I hook up an aftermarket coil on my 89 LXi? There are two plugs in the stock coil, one with a black w/ yellow stripe and blue wires to it and the other with two blue wires going to it. How do I use these (cut, splice) to make it work?
Old Jul 23, 2001 | 07:41 AM
Smashback's Avatar
Default Re: Wiring Aftermarket Coil (AMSOIL89LXi)
You need to drill a hole in the dist cap where you can extend those wires and run them out to connect to the new coil.
Old Jul 23, 2001 | 09:23 AM
New User
Default Re: Wiring Aftermarket Coil (mplex2000)
The OEM coil is separate from the distributor cap and is mounted on the passenger side fenderwell under the hood.
[Modified by AMSOIL89LXi, 12:25 PM 7/23/2001]
jazmie
Apr 1, 2010 01:14 PM
posaccord01
Mar 24, 2007 08:40 AM
USDM 4G VTEC
Feb 15, 2004 10:45 AM
turboITR#704
Jun 6, 2003 11:17 AM
gsr-t
Jul 28, 2001 06:47 PM
