Help! Brake light stays on while driving
Old Aug 3, 2001 | 10:58 PM
ingrate's Avatar
25 Year Member
Default Help! Brake light stays on while driving
I posted this awhile ago in the integra forum, but i still haven't found a solution.. you know if you drive with the e-brake just 1 click up so the "BRAKE" light inside the gauge cluster is on, it will disable the ABS. Well, even if my e-brake is all the way down, the "BRAKE" light stays on and when i drive for a while the ABS automatically disables itself. The ABS is not the root of my concern, it's trying to get the brake light to turn off when i release my e-brake. I checked the brake fluid, and it's fine. I pulled off the center console to inspect the switch, still checks fine. I double checked the 2 wires coming from the brake fluid reservoir cap, they're good to go. I've had this problem for a couple months now, and so far it seems like there is no solution! Can anybody help???
Old Aug 4, 2001 | 12:11 AM
raene's Avatar
Default Re: Help! Brake light stays on while driving (In7egrity)
Is this an intermittent problem or does it happen regularly? If it's intermittent, my brother had this problem on his CRX. I know it's completely different system-wise, but nevertheless... it was caused by a leaking wheel cylinder. Rebuilding the rear wheel cylinders solved the problem. If it's continual, sorry, I can't help...
Old Aug 4, 2001 | 04:47 AM
Jared's Avatar
make sure you have enough fluid in your reservoir as well as your abs reservoir.
Old Aug 4, 2001 | 11:13 AM
ingrate's Avatar
25 Year Member
Default Re: Help! Brake light stays on while driving (Jared)
i filled up the brake and ABS reservoir to past full and then took off my neuspeed strut bar because it was crushing the 2 wires that lead to the brake reservoir cap.. i repositioned the wires and the light finally turned off! whoo hoo!
Old Aug 25, 2001 | 06:50 PM
FCdrifter's Avatar
New User
hey this just started happening to me in my si! I haven't checked the fluids though I'll check on this tommorow morning I just realized what your post said and si's don't have abs. hmmmm any other ideas why this is happening?
[Modified by 96greengsr, 3:51 AM 8/26/2001]
dubzxallxstar
May 25, 2010 06:03 PM
mikester_91
Jan 18, 2005 01:14 PM
tegon-gsr
Oct 21, 2004 12:15 PM
monalisa overdrive
Feb 15, 2004 05:07 PM
BlueIntegraBoy
Aug 23, 2003 01:54 PM
