synchro stuffed , help !
Old Jul 21, 2001 | 03:38 AM
Cyber ITR's Avatar
Default synchro stuffed , help !
i just found out today, i was cruising 140km/h in 4th gear then i changed it to 5th
and somehow i heard the gearbox made sound like " krekkkkkk "
first time i thought i didnt put it to 5th properlly ( i mean just like half in )
then i tried again for 3 times and it made that noise
only happened when i changed gear from 4th -> 5th , the rest is fine
i just dont get it , why only happened from 4th to 5th
i never to used 5th gear to race but this actually the one dat stuffed
will be expensive to fixed the synchro ??
help me guys please.
Old Jul 22, 2001 | 03:56 AM
Cyber ITR's Avatar
Default Re: synchro stuffed , help ! (VTEC_SiR)
any help please !!!!!!!!!!!!!!!!!!!
Old Jul 22, 2001 | 07:50 AM
martilafox's Avatar
New User
you'll need to change the 5th gear syncro eventually. i have the same problem with my trans. it'll cost maybe 4-5 hundred dollars ($ which i dont have). i would suggest to change the trans fluid, and when you shift into 5th gear, don't do it right away. press the clutch; take it out of gear; waite one second; then shift into 5th.
Recaan
Transmission & Drivetrain
Aug 7, 2016 12:24 AM
HOLLAxPEENxYO
May 20, 2011 01:40 PM
missinghubcabs
Jun 25, 2003 03:41 PM
green93
Jan 5, 2003 07:40 AM
