Starting system help needed.....
Old Jul 26, 2001 | 09:58 AM
Redline130's Avatar
Default Starting system help needed.....
I need some help in trying to figure out why my car won't start. The engine turns but it won't fire up. I have a B18A in a 89 CRX with a MSD 6A and SS coil. I have tried it with and without the MSD hooked up and I get the same results. I have tried 3 different ignitors (2 brand new and 1 that was originally in the dist.). All the wiring connections are good too. Is there anything else I should be looking at? Would the main relay be a suspect? I replaced it about 10 months ago, would it go out so soon? Sorry for all the ?'s, but I'm just stumped. Any help or hints is appreciated. Aloha.
cyber13
[Modified by cyber13, 10:59 AM 7/26/2001]
Old Jul 26, 2001 | 02:05 PM
CardDealer's Avatar
Banned
Default Re: Starting system help needed..... (cyber13)
Modified by CardDealer at 4:16 AM 11/16/2006
Old Jul 26, 2001 | 03:19 PM
Redline130's Avatar
Default Re: Starting system help needed..... (schlit)
Well I did have the car out in the sun for half a day. I will look into it. Thanks.
cyber13
Old Jul 26, 2001 | 05:02 PM
t's Avatar
t
If your sure you are getting sparks to the motor and the timing is correct, than that leaves fuel. Make sure the fuel filter/injectors is not clogged up. Also check to see if the fuel pump is working (fuse).
Old Jul 26, 2001 | 07:31 PM
Redline130's Avatar
Default Re: Starting system help needed..... (t)
I am getting fuel to the injectors and into the cylinders. I can also hear the fuel pump when I attempt to start it. It is an ignition problem, I just can't seem to find it. Thanks.
cyber13
Josh Jennings
Oct 30, 2016 03:35 PM
chase.vanatta
Jun 15, 2009 05:12 PM
blue89hatch
Dec 30, 2008 05:25 AM
neuerasd9
Jan 7, 2006 09:39 PM
P-DuBB
Apr 12, 2005 08:44 PM
