ignition install/ type r throttlle body
Old Aug 4, 2001 | 03:11 PM
Nighthawk GS-R's Avatar
New User
Default ignition install/ type r throttlle body
hey, i was wondering i just purcahsed a jacobs ice pak. my first question is.....is this worth it? second wheres the best place to mount the "amp" ? also would a venom400 module work with the igniton or is just one needed? on a seperate note is a type r trottle body a direct fit a 01 gsr?
thanks
Old Aug 4, 2001 | 05:17 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: ignition install/ type r throttlle body (Nighthawk GS-R)
OMG, DO NOT, I REPEAT DO NOT buy a Jacobs **** System. You'll be part of the greatest marketing scam of your life.
Jacobs is garbage "equipment" (I use that term very loosly). Ask anyone who's ever had Jacobs stuff, and they'll all tell you it sucks big donkey ballz.....
Enough with that. If you want a good ignition, go buy a MSD Digital 6+
No, a ITR t-body is not a "direct" bolt on. You'll need to change the throttle linkage out. Otherwise, it fits fine.
Why do you think you need an igntion anyways? Are you running turbo or NOS??
Old Aug 4, 2001 | 06:05 PM
Jared's Avatar
Also a Venom 400 module is a POS. All it does is make the ECU think you're at more throttle than the TPS is actually showing. Does nothing, you can push the throttle harder(except at wot, of course) and achieve the same effect.
S1_DJai
10
Dec 1, 2005 11:03 PM
Modify
Jun 27, 2004 09:27 PM
Drum_Guru
Sep 21, 2003 06:58 PM
Jsracingintegra
Jul 26, 2002 11:22 AM
iwantfastcars
May 17, 2002 03:51 AM
