Code 22 - VTEC System Malfunction
Old Jul 18, 2001 | 03:58 AM
.brad's Avatar
25 Year Member
Default Code 22 - VTEC System Malfunction
blah, i want to throw up
the other day my car bogged down and my check engine light came on...
I pulled over and turned off the car and looked in in the engine bay and everything looked cool, i cranked the car up after a few minutes of debating and it started up fine. Seemed to drive fine on the way home. Drove fine with no noises until this morning.
Now when I get on the gas just a little bit, (normal acceleration) is sounds like something's knocking something else almost like a flat spot in a tire, how when i accelerate it speeds up too.
Well I just checked the ecu to see what it'd tell me and it said "beeeeeeeeeeeeeeeeeep beeeeeeeeeeeeeeeeeeeeeep beep beep" - So I ran inside and looked it up...
Short or open in VTEC circuit, bad VTEC solenoid valve, Bad VTEC pressure switch.
I'll run it by my guy when I get a chance but I'm almost too paranoid to drive it! Has anyone had any previous experience with this?!? Help!!!
Old Jul 18, 2001 | 10:46 AM
raene's Avatar
Default Re: Code 22 - VTEC System Malfunction (Lo Phat)
This happened to me before. The wire had pulled out of the bottom of the plug for the VTEC solenoid. All I had to do was plug it back in and the car was very, very happy. I'd check for shorts (or, as in my case, a loose wire) before you start pulling things apart...
Old Jul 18, 2001 | 10:52 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Code 22 - VTEC System Malfunction (raeneshadow)
I got the same code once too. It was because I had a loose wire on the VAFC.
ghettoSi
Jan 11, 2008 11:39 PM
ITR0950
Oct 18, 2007 10:10 AM
Pr0ject93hb
Sep 14, 2007 09:50 AM
lostkoz
Aug 11, 2006 06:27 PM
dkboyny11
Jun 2, 2005 03:45 PM
