Neutral safety switch part II...
Old Aug 1, 2001 | 12:21 AM
raene's Avatar
Default Neutral safety switch part II...
Since it's a M/T I guess it's actually not a NSS, but whatever... the thing that won't let you start the car if the clutch isn't pushed .
I picked on up at the wreckers' for $5, fabricated my own bracket and installed it (the '89-'91 CRX brackets are different than the '88's). Now I just need to know how to wire it. I assume it's an interrupt for the starter solenoid? Can anyone provide some info on this?
Old Aug 1, 2001 | 07:09 PM
t's Avatar
t
Default Re: Neutral safety switch part II... (raeneshadow)
It should be just one wire. And that wire goes to the chasis.
To start, ground to chasis.
[Modified by t, 8:10 PM 8/1/2001]
Old Aug 1, 2001 | 07:10 PM
raene's Avatar
Default Re: Neutral safety switch part II... (t)
How could just one wire running to the ground control anything? I already picked one up, and it's a two-wire pushbutton switch... kinda like a doorbell.
Old Aug 1, 2001 | 07:15 PM
t's Avatar
t
Connect one wire to the existing wire that goes to the starter interupt relay and the other "one" wire to chasis.
Or you could just connect that existing wire to the chasis and you could start with the pedal up. Many ways to do this.
You could have a switch in a hidden location and no one can start without hitting the switch.
Its just "one" wire (blue/black?) that needs to be grounded to start.
[Modified by t, 8:18 PM 8/1/2001]
Old Aug 1, 2001 | 07:21 PM
BreakStuff's Avatar
New User
The safety switch you describe would be similiar to your brake switch.. are you trying to "bypass" this switch or add it on?
Yes it is a simple switch just like a doorbell.. except for one issue..
I do believe that with the switch "protruding" out the circuit will be "closed", and when you push it in, the switch circuit will be "open"
kinda opposite the doorbell theory...
billyhoe
Dec 21, 2020 11:52 AM
nsxxtreme
Audio / Security / Video
Jun 17, 2010 08:04 AM
epicbeats
Jul 29, 2009 12:59 PM
