Push button ignition install on 98 gsr
Old Jul 31, 2001 | 06:54 PM
sicilian2k1's Avatar
New User
Default Push button ignition install on 98 gsr
what is the easiest way to do this? will it interfere with my alarm in any way? i got the push button starter from a totaled s2000, but i have no idea what wires i am looking for or any other details...if someone could please help, it would be appreciated
Old Aug 1, 2001 | 07:15 AM
riot's Avatar
Default Re: Push button ignition install on 98 gsr (sicilian2k1)
http://www.jdmfan.com/howto/cosmetic..._start_button/
your welcome...and no it wont interfear with the alarm...it didn't with mine.
-ryan
Old Aug 1, 2001 | 07:48 AM
nerdish's Avatar
Default Re: Push button ignition install on 98 gsr (riot)
Ryan, what car did you put it in?
Got any pics? I'm about to install mine.. I think I'm gonna use the dimmer switch location and re-route the dimmer to the glove box or something. I don't want to put it where the cruise control button is because then the passenger can't see me push it.
Old Aug 1, 2001 | 10:34 AM
RoaringTurtle's Avatar
New User
Default Re: Push button ignition install on 98 gsr (nerdish)
here is mine
got the info on how to set it up at jdmfan.com as well
Old Aug 1, 2001 | 10:36 AM
nerdish's Avatar
Default Re: Push button ignition install on 98 gsr (RoaringTurtle)
Your pic dun work.
Old Aug 1, 2001 | 12:32 PM
New User
yeah it does, i can see it fine
Old Aug 2, 2001 | 01:38 PM
Wet Nudl's Avatar
New User
NOS, from the instruction given by this site, looks like you can still crank the starter with the key.. The instruction say to splice but not cut the thick wht/blk wire.
Old Aug 2, 2001 | 07:34 PM
99VTECex's Avatar
New User
Default Re: Push button ignition install on 98 gsr (TypeRP)
If you cut it then turning the key to start would not start the car (obviously). That is your choice. It can be done safely either way. If you do have an alarm and you do decide to cut the wire make sure you cut above where your alarm splices into the starter wire. (closer to the key side). And make sure that you tape off the key side of the starter wire other wise it might touch metal and blow a fuse or start sparking.
Good luck
Matt
White 99 EX
97civicsedan
Apr 19, 2007 03:12 PM
ogdogg16
Audio / Security / Video
Apr 10, 2003 08:13 AM
2fknlo
Mar 7, 2002 05:37 AM
AZZKIKR
Jul 12, 2001 03:43 PM
