running rich, side effects.
Old Jul 31, 2001 | 06:06 PM
quikrpm'z's Avatar
Default running rich, side effects.
just need to know? Is it possible for the gas to drain by the rings?
Old Jul 31, 2001 | 06:25 PM
Katman's Avatar
Default Re: running rich, side effects. (quikrpm1)
uhh..if your combustion chamber does fill up with gas I wouldn't wanna be around yer car- kaaaaaBOOOM!
I believe your car would run really really shitty if the the cylinder did fill up with gas though...
[Modified by Katman, 7:25 PM 7/31/2001]
Old Jul 31, 2001 | 11:04 PM
raene's Avatar
If you're running rich enough that gas is pooling in the cylinders, then it's going to burn the oil off the cylinder walls, causing excess wear and tear upon the rings, eventually frying them.
Old Aug 1, 2001 | 01:26 AM
d0nkeyxPunch's Avatar
Banned
Default Re: running rich, side effects. (raeneshadow)
How do you know if you are running rich or not?
Old Aug 1, 2001 | 05:16 AM
Shinmantis's Avatar
Default Re: running rich, side effects. (FastxCivic)
Check your spark plugs
Old Aug 1, 2001 | 05:03 PM
quikrpm'z's Avatar
Default Re: running rich, side effects. (Teken)
i know im running rich because i dyno'd the car and its running rich.
My plugs are black. I dont have to worry about the cat, cause i dont have one. Smell i do have one but it smells more like burning oil, yet i dont have low oil levels. I some time have irratic idle, except it tends to dip low? Cant explain that one.
Im more worried about what Raenae said (sp, sorry), We both have the same theory. I can hear some kind of whinning around 3k and above which is where the rich cycle begins. Im afraid the richness isnt allowing the rings to seal properly, along the cylinder wall.
Old Aug 1, 2001 | 06:39 PM
raene's Avatar
For what I said to happen you'd have to be running rich enough that gas was coming out your tailpipe in dribbles, so don't worry too much. If you're just running a little bit rich, try picking up an adjustable FPR and lowering the pressure in 0.5 increments until it runs stoich, or better yet makes max power.
And dude, get a catalytic converter. I hate it when people punch their cats.
Old Aug 2, 2001 | 03:49 PM
3.3.3's Avatar
when your @$$ is puffing black clouds of smoke....
Old Aug 2, 2001 | 09:00 PM
MaxPowerIntegra's Avatar
...brilliant... look at your bumper if its black from the exhaust fumes.. then bingo!
poormans_typer69
Oct 3, 2007 02:32 PM
importfanatic17
Jan 2, 2007 04:32 PM
Layziebtnh055
Apr 13, 2004 06:26 PM
Loveless
Apr 2, 2003 03:17 PM
Flamenco-T
Nov 23, 2001 09:38 AM
