tranny problem + double clutch question
Old Jul 18, 2001 | 01:21 PM
DreamSpeed's Avatar
Default tranny problem + double clutch question
ok, basically the synchros for my third gear is screwed up, shifting at anything pass 3000 rpm will result in grinding, i have found out that by double clutching when i downshift i can bypass the use of the synchros and shift without grinding however, i cannot get the method to work while upshifting, and when i sit down and think about the mechanics behind double clutching i realize that it won't bypass the use of the synchros on an upshift because you have to slow the rotational speed down not increase it, so therefore my question is, is there a way to bypass the use of a synchro on an upshift because having to shift from 2nd to 3rd at 3000 rpm all the time really sucks
Old Jul 20, 2001 | 04:28 AM
serious's Avatar
Default Re: tranny problem + double clutch question (DreamSpeed)
yeah, there is. the layshaft, when disengaged from the rest of the transmission and from the engine, will naturally slow down, so to upshift without using your synchros, you have put your clutch in, shift to neutral and pause the correct amount of time before putting it into gear. i usually use engine rpms to guage when to shift up, i know the engine and layshaft aren't connected with the clutch in, but it helps to time your shift.
Old Jul 20, 2001 | 12:15 PM
DreamSpeed's Avatar
Default Re: tranny problem + double clutch question (serious)
ok, cool thanks, i'll give it a try
Demonis
Honda Civic (2006 - 2015)
Mar 24, 2007 09:37 AM
5 Skware
Apr 13, 2005 05:04 AM
94GSRNewbie
Aug 4, 2001 11:48 PM
