LS/Vtec in an eg
Old Aug 23, 2002 | 04:23 PM
GDM Z28's Avatar
Default LS/Vtec in an eg
Hey guys im looking to do a swap in my p5 dx hatch and i really want to build a LS/Vtec. What i was going to do was get a b18b swap (LS) and then l8er on just get the b16 head. Then someone told me i will have to change some parts out after i get the new head. Like axles and stuff. IS this true? What should i expect to run into when i put the new head on? BTW im not installing the new head, i will have a honda specialist do it. Thanx for any help.
Old Aug 23, 2002 | 04:59 PM
Kataku2K3's Avatar
Default Re: LS/Vtec in an eg (civicflnum1)
Axles should work fine but there are a few things i would normally change when building even the most simple LSVTEC. First get the VTEC head, then ur gonna need a VTEC ecu such as a GSR, P30, or a chipped P28. I would definately swap the tranny to either a GSR or B16 but either will be fine. If you keep the LS you will be losing power unless you are planning on building a really crazy turbo motor that can spool for a long time. When i have built LSVTECs in the past i've normally swapped the pistons too. I hate stock bottom end. Besides if you just use a stock PR3 head ur comp ratio is like 9.55:1 and a GSR head will raise you slightly higher to around 9.75:1. The best way to go is with some JE's and get ur comp ratio to around 12-12.5:1 I built my friend's LSVTEC last weekend and just used a stock B16 head with .25mm over PR3 pistons. Just that little change bumps up the compression to around 11.38:1. Just remember the basics to get the motor running from a stock LS to LSVTEC are... VTEC head, ECU, (tranny most of the time), timing belt and water pump are good to change, and ur oil line. Have fun and i hope this helps a lil!!
[Modified by JDMspecEG6, 6:02 PM 8/23/2002]
Old Aug 24, 2002 | 07:41 AM
EG6owner-T's Avatar
Default Re: LS/Vtec in an eg (JDMspecEG6)
oh yeah make sure you upgrade your oil pump to a type r or b20
skillzhb
Jan 10, 2009 10:40 PM
wernhersey
Sep 19, 2006 09:30 AM
bboysake
Jul 10, 2006 09:44 AM
pedrobabone
Nov 17, 2005 08:14 PM
JDM_Risa
Mar 16, 2003 01:42 PM
