Question for skunk2 coilover owners.
Old Aug 22, 2002 | 11:03 AM
VTECorona's Avatar
Default Question for skunk2 coilover owners.
I noticed that my adjustable screw\perch things are at different levels on each side but the ride height is still the same. Like my left rear is screwed all the way down to where the cup is at the bottom of the shock and the other one is like 1" higher and the ride height is the same on each side. Its the same on the front but not as dramatic of a difference.
Old Aug 22, 2002 | 02:46 PM
VTECorona's Avatar
Default Re: Question for skunk2 coilover owners. (97RedTegGSR)
Cough::::cough cough
Old Aug 22, 2002 | 05:09 PM
Dodger2940's Avatar
Thats intesesting. It should not be like that. I know mine are not.
Old Aug 22, 2002 | 08:56 PM
carcala's Avatar
my friend had this problem. he had the springs switched. the springs in the front are different from the rear by weight. check to see that u have the springs in the right sides.
Old Aug 22, 2002 | 10:27 PM
VTECorona's Avatar
Default Re: Question for skunk2 coilover owners. (carcala)
yup the xxx.xxx.010 in front, xxx.xxx.080 in the rear. Its pissing me off because its riding like crap too, I can't figure out what the hell is wrong. Maybe an alignment would fix it?
Old Aug 22, 2002 | 10:53 PM
carcala's Avatar
how low is ur car? My friends car is really low and it also rides like crap. I think the higher weight goes in the front due to the weight of the engine and the lower one in the rear.
Old Aug 23, 2002 | 04:05 AM
Ricky Rojales's Avatar
This is my solution to such high spring rates and shorter shocks for the SKUNK2s ~> https://honda-tech.com/zerothread?id=255779
Look for my first posts.
And as far as your height goes... it will differ. If your really care about how the car handles then get it aligned and cornerweight-balanced.
HTH
[Modified by Whimsical Smiley, 8:12 AM 8/23/2002]
Old Aug 23, 2002 | 08:21 AM
VTECorona's Avatar
Default Re: Question for skunk2 coilover owners. (Helmet Head)
Its not slammed or anything, its pretty close to it though. I can slide my fingers under the wheel well and slide them across the top of the tire. Its weird because my right front perch is screwed up high and the spring is compressed a little while the other side is lower and the spring isn't compressed. Same deal for the rear, I don't understand how all this **** is possible. Everything is torqued to factory specs, all the right parts are in the right place.
Old Aug 23, 2002 | 09:56 AM
My guess is that SKUNK2 coilover springs are not the same high quality as Eibach (sagging) and that the SKUNK2 springs are a inch too short...
Old Aug 25, 2002 | 04:57 PM
neutron91's Avatar
i think the lighter weight springs go in the front and the heavier in the rear... im pretty sure this is right... but i could be wrong
Old Aug 25, 2002 | 06:29 PM
XMarkGuerillaX's Avatar
thats funky mine are even steven....
95BoostedEJ1
Suspension & Brakes
May 29, 2009 06:43 PM
tekturbo
Suspension & Brakes
10
Feb 20, 2008 08:22 PM
cmross13
Suspension & Brakes
Oct 2, 2007 06:30 PM
robtackett
Nov 22, 2005 08:08 AM
JokerTypeR
32
May 24, 2005 09:24 PM
