adding 2 injectors
Old Aug 21, 2002 | 10:01 PM
89 CRX SI's Avatar
Default adding 2 injectors
can i drill in 2 more injectors into my IC piping and run them through a relayed switch. Wil this just work like that by adding fuel when i need it? thx guys
Old Aug 21, 2002 | 10:10 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: adding 2 injectors (89 CRX SI)
http://www.sdsefi.coma check under the additional injector controller.
stan
Old Aug 21, 2002 | 10:22 PM
89 CRX SI's Avatar
Default Re: adding 2 injectors (90crxsi)
waay too much money. cant i just use them on a rpm switch so when i hit the higher boost they turn on and pump fuel... do i realyy them them to be timed or pulsate?
Old Aug 21, 2002 | 11:54 PM
Kamin's Avatar
no
how are you gonna get the injectors fuel?
your gonna need to tap into the fuel line/rail also
this just isnt pheisable.
its a saftey issue. im sure you dont want your engine catching on fire here if your running a fuel line to your intake piping and it accidentally comes loose.
whats your fuel setup?
maybe you dont even need them.
Old Aug 22, 2002 | 08:59 AM
89 CRX SI's Avatar
Default Re: adding 2 injectors (KAMiN)
its easy to get fuel to the injectors just tap off you fuel rail. it is the same way the EIC fromSDS uses. i just dont see the need for a pulsater or anything like that as its gonna go into different cylenders anyhow. like i just want it to spry fuel hard core.
I heard of people using old VW cold start injectors too......
Old Aug 22, 2002 | 09:43 PM
89 CRX SI's Avatar
ttt someones gotta no this
Missouri_Civ
Aug 20, 2007 07:28 AM
Dan_the_MaN
Nov 15, 2005 03:04 PM
92lsvteceg6
Nov 5, 2005 10:40 AM
Sinner
Jun 8, 2003 03:03 PM
baonest
Aug 5, 2001 02:51 PM
