Difference between B16a1 and B16a2 heads?
Old Aug 21, 2002 | 10:46 AM
Ri5e's Avatar
Default Difference between B16a1 and B16a2 heads?
I already did a search and can't seem to find an answer. I am about to buy a b16a1 head but I want to know what the difference is between that and the newer b16a2?
I will be replacing the valve springs and retainers so the head being 13 years old won't be a problem. However I heard that the newer b16 head has better flow? is this true? A port and polish job will fix that up?
Also I heard that the B16a1 camshafts have a less agressive lift compared to the b16a2, is this true?
Links would be nice too! thanks.
[Modified by BG Boost, 7:47 PM 8/21/2002]
Old Aug 21, 2002 | 11:14 AM
Spade's Avatar
Default Re: Difference between B16a1 and B16a2 heads? (BG Boost)
a port and polish will more than do the job for you.
The main difference is the cams.
Old Aug 21, 2002 | 11:15 AM
WAFFLES's Avatar
Default Re: Difference between B16a1 and B16a2 heads? (Spade)
cams, oil passages(but not much different), and Intake manifold
Old Aug 21, 2002 | 08:05 PM
lazy bum shaughn's Avatar
I'm pretty sure the B16A2 has a larger throttle body(2mm larger) than the first generation B16A.
boostedblue23
Mar 19, 2018 03:18 AM
PWRD BY HONDA
Nov 1, 2009 04:13 AM
oMek
Apr 11, 2004 08:37 PM
CrazyKoreanCrx
Feb 26, 2003 03:09 PM
Ri5e
Feb 26, 2002 05:18 PM
