Checking for Vacuum leaks:?
Old Aug 20, 2002 | 05:29 PM
LshatchTurbo's Avatar
New User
Default Checking for Vacuum leaks:?
Besides the line that goes from the top of the intake manifold to the top of the fuel pressure regulator, where else should i be looking to check for vacuum leaks. This is a 95 ls engine btw. Thanks
Old Aug 20, 2002 | 05:57 PM
ScrapinSi's Avatar
Default Re: Checking for Vacuum leaks:? (lshatchturbo)
start the car, and begin spraying carb cleaner around your engine bay... when the car bogs, that is where your leak is.
Old Aug 23, 2002 | 07:09 AM
jetdriven's Avatar
run an unlit propane torch along your hoses and manifold. when the idle smoothes out and speeds up youve found the leak.
hmtcrxsir
Apr 17, 2017 08:13 PM
z28matt
Dec 17, 2009 09:22 PM
heeltoehonda
Oct 25, 2009 06:46 PM
