how to compression test??
Old Aug 21, 2002 | 04:06 PM
JCracer723's Avatar
Default how to compression test??
how can i do a leak down test or compression test when the engine its not in a car wut tool do i use where do i get it?
[Modified by JCracer723, 1:08 AM 8/22/2002]
Old Aug 22, 2002 | 12:07 AM
salbaje's Avatar
Default Re: how to compression test?? (JCracer723)
get a compression tester and plug it in the sparkplug holes and turn the crankshaft pulley
Old Aug 22, 2002 | 09:42 AM
JCracer723's Avatar
Default Re: how to compression test?? (salbaje)
i had that it mind, but i was told the it need it to be crank really fast thats why its better to do it in the car. have u done it before???
Old Aug 22, 2002 | 12:25 PM
Turbo Powa's Avatar
its a good idea to do it in the car. take out the sparl plugs and also get a starter to turn the engine or get a friend to do it. Let it do about 5 turns. Also do not forget to push the button on the compression tester after you tested the cylinder to let the pressure out. Then do the same for the other cylinders.
Old Aug 22, 2002 | 12:53 PM
JCracer723's Avatar
Default Re: how to compression test?? (Civic LX 29)
ok yes i know that way ! but the engine its not in the car!!
Old Aug 22, 2002 | 01:07 PM
Screaming Vtec's Avatar
Can you not hook the starter to turn the engine over? just wire it straight to a battery
Old Aug 22, 2002 | 01:50 PM
Turbo Powa's Avatar
Default Re: how to compression test?? (Screaming Vtec)
Try it that way
Old Aug 22, 2002 | 02:05 PM
JCracer723's Avatar
no tranny !! i just have the long block and i wanna see in wut condition it is
Old Aug 22, 2002 | 03:17 PM
JCracer723's Avatar
HHHHHHEEEEELLLLLLOOOOOO after hours and hours of thinkin i dunno why it just hit me!! "juan get a impact gun and crank it" "while ur friend(carlos) checks the damn pressure" jejeje ill let u guys know if it works
Mavrick
Nov 14, 2007 07:38 PM
DropSide
Apr 18, 2007 06:22 PM
FK00GSR
Apr 14, 2005 06:03 AM
StupidSlowRSX
Nov 26, 2004 06:57 AM
paulzy
Jan 8, 2003 04:05 AM
