P28 and harness installation ?
Old Aug 22, 2002 | 10:23 AM
jack25racing's Avatar
Default P28 and harness installation ?
I just finish to built my harness obdII-obdI but I don't have my chip yet for my P28 ecu, so I need to know if I can install (just for testing) the harness and the ecu without the chip or this can damage something ?
Thanks !!!
Old Aug 22, 2002 | 10:39 AM
boomslang's Avatar
Default Re: P28 and harness installation ? (jack25racing)
Just for idling and farting around it'll be okay. Don't do any full throttle stuff though.
Old Aug 22, 2002 | 11:04 AM
Default Re: P28 and harness installation ? (Inlinefour)
Ok, do you think that with my VAFC it's will be possible to engage the vtec without any risk or I am better to disconnect the VAFC.
Old Aug 22, 2002 | 01:32 PM
boomslang's Avatar
If you don't throw any codes, then the harness works.
Old Aug 22, 2002 | 02:57 PM
My check engine is ON so I probably have some bad connection with my harness. The car Idle great and everything seem to be OK. My VAFC work and I inspect few time the harness and everything is suppose to be good. Do you know if I can read the error code by myself or I don have the choice and need to go at dealer.
This I the diagram I use to built my harness !!
http://www.jdmfan.com/technical/perf...obd1/index.inc
Old Aug 22, 2002 | 03:05 PM
Spade's Avatar
Just insert a paper clip into the service plug and count how many times the check engine light blinks.
Courtesy of Katman.
Old Aug 23, 2002 | 06:22 AM
Default Re: P28 and harness installation ? (Spade)
I will try this beginning of the coming week but do you know if the ecu check for Knock sensor or vtec pressure swith or something a non vtec integra don't have. right now it my VAFC that control my vtec and I use my P75 ecu.
Thanks
Old Aug 23, 2002 | 08:05 AM
ttttt
wizeguy1
Apr 14, 2007 02:21 PM
Maldito X
Nov 25, 2006 03:49 PM
jazz215
Sep 25, 2003 03:13 PM
iperez
Sep 19, 2003 01:37 PM
ModlesSI
Feb 11, 2003 05:18 PM
