Alternator Ques?
Old Aug 21, 2002 | 12:46 AM
DarkSol97's Avatar
Default Alternator Ques?
Can A 99 civic Si alternator would be able to plug directly on a 94 GSR engine? Wiring wise? Thanks! any info would be greatly appreciated!
Old Aug 21, 2002 | 12:48 AM
poison's Avatar
Default Re: Alternator Ques? (DarkSol97)
Yes, wiring wise they will go right in I believe.
Old Aug 21, 2002 | 12:54 AM
DarkSol97's Avatar
Default Re: Alternator Ques? (poison)
hmmm, the reason Im asking this is because of the slight differences between obd1 and obd2? I was wondering if the obd1 and obd2 plugs are different?
Old Aug 21, 2002 | 01:01 AM
poison's Avatar
not for alternator, they aren't.
Old Aug 21, 2002 | 02:33 AM
EE_Chris's Avatar
Default Alternator Question
Although not 94, looking into my 98-00 Teg and 96-99 Civic ETM's, they do 'appear' to be swappable.
The only wiring difference I see is the "Charging Light Indicator" pins for the ECU.
On the Civic, its a white/blue wire that starts at the alternator [pin 3], goes into B16, then out B15, then to V+
On the Teg, its a white/blue wire that starts at the alternator [pin 3] goes into D9, then out B11, then to V+.
[Modified by EE_Chris, 11:35 AM 8/21/2002]
PabloM
Mar 10, 2014 04:58 PM
qpzm12
Nov 6, 2010 05:47 AM
lsvtechatch92
Mar 7, 2007 06:44 PM
NoSiR
May 7, 2004 09:41 AM
