Need help with turbo
im trying to turbo charge my ls/vtec, is there another place to tap the oil feed line other than the t fitting cause thats where my vtec oil line is at. i heard theres a part that you can use to tap it to the oil filter, if so how do i use that if i got a jackson racing oil cooler and relocation kit, any ideas
thanks
thanks
you better have a vtec oil pump!! and i'm not sure if there is another way to get oil to your turbo other than to use the same oil line that's hooked up to your vtec head.
i'm guessing you had to make a tee somewhere for your oil feed line, if you did i'd get to the other part of your "T" for the new oil line. eveyone used to just tee of the back of the block, and now unless you got that special fitting from Z10 it is best to tee from the tirewall.
crx1856
Nov 2, 2003 11:50 PM
DR. ON POINT
Sep 19, 2002 09:31 AM
