B16a w/ B17a Crank?
theres great advantages and of coarse disadvantages.what kinda build are u thinkn?a built b16 opposed to a ls/vtec?the b16 w/t a b17 crank would be highly more efficient than a ls/vtec(my opinion)you could bore the b16 to 86mm,already have oil squiters,the b17 crank is far more superior than a non vtec crank.u actually have more displacement than a frank,also iliminate the rod*stroke problem.only problem would be the valve to piston clearance after the boreing.other thoughts welcome
If you use the B17A crank and rods (yes, you would need these, too) with B16A pistons, you would basically have a B17A with higher compression. As for the rod ratio, it would decrease from 17.4:1 to about 1.62:1. So it would still be quite good.
i feel like a newjack but
what car comes with a b17a?
and is it worth it
about how much hp would it get on a b16a with ihe
[Modified by redline201, 3:29 AM 8/27/2002]
and is it worth it
looking for b17a crank and rods.. guys pls post here if your selling a b17a rods and crank or emali me spoonskiee@yahoo.com tanx!!!
Here this is from G2IC http://www.g2ic.com/forums/showthrea...ight=b17+crank
Has anyone done this. Good points and bad points to doing this setup?
My old setup (aka Blacksheep), was a B16A3 block, B17 internals with standard size CTR slugs, stock headgasket and 89 B16A head. I ran a Spoon intake cam and ITR exhaust cam which ran of a Skunkworks reprogrammed P28 ecu. I dynoed about 175whp and about 123ftlbs of torque. That's with the cam sprockets dialed in too. I think i coulda squeezed out some more power though...but I didnt care, it was perfectly set to my liking for road racing.
and is it worth it
and is it worth it
