Rev?
Old Aug 22, 2002 | 06:39 AM
Hondasaurs's Avatar
Default Rev?
I just put a cold air intake on my car. Now my engine revs up to 1500 and drops down to 800 when sitting still. What is causing this and what can I do to fix it?
Old Aug 22, 2002 | 08:41 AM
avividmemory's Avatar
Default Re: Rev? (ZC_CRX)
if its idling at weird intervals, its probably your o2 sensor
Old Aug 22, 2002 | 09:23 AM
bullz's Avatar
Check you breather valve and make sure it connected properly too.
Old Aug 22, 2002 | 06:55 PM
Hondasaurs's Avatar
Default Re: Rev? (iLLestjr)
I've checked all of these things and the problem still exist. I checked the ecu and it is not throwing any codes. I appreciate all of the info you guys have given me so far. Any other suggestions?
Old Aug 22, 2002 | 09:43 PM
Aron Parsons's Avatar
reset your idle, using the adjusting screw on the TB. then reset your ECU. the problem is that it's getting too much air, and the EAVC can't compensate, so it searches for the correct idle speed (750rpm) by opening and closing. be sure to reset your ECU afterwards.
Old Aug 22, 2002 | 09:59 PM
Hondasaurs's Avatar
Default Re: Rev? (OvERaCiD)
thanks, ill try it in the morning.
Old Aug 22, 2002 | 10:52 PM
voltronR34's Avatar
Same type of problem happend to me. Go over all of your vacume lines very carefully. There is most likely a leak somewhere and just resetting the ecu won't do anything for it.
Old Aug 24, 2002 | 10:26 AM
Hondasaurs's Avatar
Thanks so much....This fixed the problem. I've driven over 100 miles since last night and it runs great! Thanks Again!
[Modified by ZC_CRX, 2:26 PM 8/24/2002]
91dxhatch
Jan 4, 2007 11:46 AM
arychel
Mar 15, 2006 08:20 PM
snouka
11
Mar 25, 2005 06:01 AM
saucyhatch
10
Nov 13, 2003 08:25 PM
Extent
Dec 29, 2002 02:22 PM
