abnormally high idle > HELP
Old Aug 21, 2002 | 02:07 PM
b18c1delly's Avatar
Default abnormally high idle > HELP
cold start rpm @ 2500 > when it used to be 800 tops
b18c1 mods ( new plugs + wires & header only )
Old Aug 21, 2002 | 02:09 PM
Spade's Avatar
Default Re: abnormally high idle > HELP (b18c1delly)
Cold start is 2500? What is it after the engine is hot?
Old Aug 21, 2002 | 02:14 PM
b18c1delly's Avatar
Default Re: abnormally high idle > HELP (Spade)
pretty much everytime i start the ride > didnt do this before
the mods i had
Old Aug 21, 2002 | 02:18 PM
Spade's Avatar
So you are running an idle even hot at 2500?
b18c1delly's Avatar
correct on that
Old Aug 21, 2002 | 02:22 PM
Spade's Avatar
Get a bucket of water.....and wet your hand...feel around the vaccum hoses....more than likely you have a vaccum leak somewhere.
Old Aug 21, 2002 | 02:29 PM
civic_hb96's Avatar
my car was doing this the other day..
are you getting any codes?
i was getting code 7: Throttle Position Circuit Reading too high, low, short or open, bad TPS
checked the TPS and it was a bit loose.
Old Aug 21, 2002 | 07:39 PM
bluedelsol's Avatar
Default Re: abnormally high idle > HELP (civic_hb96)
i got that same thing after i put new plugs, plug wires and smaller 2" custom intake on my del sol, probly because i dont have my vacume line hooked up to my new intake, not shure, i just turned down my idel and put a small filter on my vacume line
Old Aug 21, 2002 | 08:42 PM
mashb16a's Avatar
Default Re: abnormally high idle > HELP (bluedelsol)
I used to have this problem also. Come to find out the IACV's sometimes stick open. I was instructed to take off the IACV, clean it with carb cleaner, and then spray in some WD-40. Haven't had the problem since.
candm2000
29
May 25, 2014 05:57 PM
catback91
Jan 25, 2014 01:54 PM
jdm_vizionz
Mar 2, 2010 10:49 AM
