switching ECUs in a 97 delSol
Old Aug 20, 2002 | 09:12 PM
riceboy's Avatar
Default switching ECUs in a 97 delSol
Assuming the stock OBD2 delSol ECU is pulled and a replacement OBD1 ECU is used with the Skunk2 harness, which ECU would need to be used? Anyone have experience in this?
Thanks
Old Aug 21, 2002 | 05:44 AM
CHEETAH's Avatar
Default Re: switching ECUs in a 97 delSol (riceboy)
if del sol sohc non vtec, use the 92-95 civic CX and DX (P06 ecu)
if sohc vtec, use the 92-95 civic EX/Si (P28 ecu)
if dohc vtec, use the 92-95 del sol b16a (P30 ecu), 92-93 GSR (P61 ecu), or even the 94-95 GSR (P72 ecu). I can also reprogram the P28 to DOHC spec, a very common thing people do nowadays.
Greg
Frost7177
May 8, 2008 01:19 PM
tc_gts
May 11, 2006 06:32 PM
pdiggitydogg
Sep 25, 2003 03:22 PM
cjames235
Apr 16, 2002 08:04 AM
