Dont know if this is a problem or not???
Old Aug 20, 2002 | 03:59 PM
mugenracer's Avatar
Default Dont know if this is a problem or not???
The cold start valve (IACV) in my B18C T/B became clogged last year and it was messing up my idle (going up and down) so i just plugged the valve and re-set the idle and it cured the problem. i always meant to take of the T/b and clean the valve but only got round to it today, so now i have that sucking noise thru the intake when you shut off the engine. Anywho i also reconnected the breather line to the intake (it was just blowing to free air) i took the car for a run and everything worked fine, but when i went to brake the brake pedal was near rock solid but the brakes worked fine, possibly even better!! So what i done have any bearing on the brakes, does the master cylinder for the brakes rely on air pressure from the I/M or throttle body, if not what could have done this to my brakes as i never touched anything else in the engine!
[Modified by mugenracer, 10:35 PM 8/20/2002]
Old Aug 20, 2002 | 09:35 PM
mugenracer's Avatar
Default Re: Dont know if this is a problem or not??? (mugenracer)
ttt
Old Aug 20, 2002 | 10:28 PM
91f22's Avatar
sounds like you disconnected the brake booster or you may ahve a faulty one way check vavlve if you are hearing a hidding sound after the engine is shut off the vavle could be bad and letting vacuum reserve in the booster bleed back into the intake?
Old Aug 21, 2002 | 01:05 PM
mugenracer's Avatar
Default Re: Dont know if this is a problem or not??? (91f22)
bump
DUKE LADUKE
25
May 10, 2011 09:21 AM
pythoner
Suspension & Brakes
Sep 11, 2008 05:06 PM
sicrx69
Nov 15, 2007 02:19 PM
spender1326
Apr 30, 2004 06:09 PM
