My LS/VTEC is losing torque. HELP!!!!!
Old Aug 20, 2002 | 09:31 AM
Carpediem291's Avatar
Default My LS/VTEC is losing torque. HELP!!!!!
I did my engine swap about 4 months ago. Everything was doing fine. However, my car is losing torque. I suspect that the culprit is a vaccuum leak in my intake manifold but I am not really sure. Based on your experienced what could cause this problem and how would I fix it?
Old Aug 20, 2002 | 10:57 AM
WAFFLES's Avatar
Default Re: My LS/VTEC is losing torque. HELP!!!!! (BLACKHATCHY)
Check vaccum lines like you said, but one thing I am curious about is your break in on the motor. If you didnt break it in properly the motor will become less strong.
Old Aug 20, 2002 | 12:56 PM
Default Re: My LS/VTEC is losing torque. HELP!!!!! (WAFFLES)
I don't really push my motor to the max. In fact I pretty much baby the motor for the first couple of thousand miles. I don't have a lot of knowledge on fixing engine. I had someone else to do my engine swap. What steps are required to check the vaccuum lines. Do I need to take a part my engine or just the intake manifold? I can take my car to the shop but I know they're going to charge me up the *** hourly to find the problem so I thought If I can pinpoint the actual source of the problem it can save me some money or I can replace any defective parts on my own.
chinkstahh
Jun 13, 2009 05:02 PM
billyVR6
11
Jul 30, 2004 01:31 PM
rkn527
Jul 16, 2003 06:03 PM
jmartinson
Mar 27, 2003 04:51 PM
TriCkSpEeD
Jul 24, 2001 12:35 PM
