B18A help
Old Aug 23, 2002 | 04:15 PM
FifthGearOnline's Avatar
Default B18A help
ok i got this e-mail today from a guy looking for some help with is b18a motor....thanks guys
heres the question:
I recently blew up my B18A motor and called a place for a newe one when I got there the korean guy told be he had a b18b motor and htat it was the same. I later came to find that it realy isn't I was told I couldn't install it with out an ecu which he didn't sell me with the motor. I called the sales place back he told me to use the Intake off of my old motor and a wireharness from it to. so now my prob is that not all the connections match and there is a sensor on the intake side of the block right next to the oil filter that isn't on the new block.
Now I found a way to use my wiring harness but the only problem is that sensor that isn't on the new block will my car run messed up with out having it connected, I un bolted it and it is a water temp gauge will it affect the way the car runs since it's not on the new block.
Old Aug 24, 2002 | 07:49 AM
Quick 200k Mile Motor's Avatar
Default Re: B18A help (FifthGearOnline.com)
The sensor youre talking about is the knock sensor (its green).
The newer (94' and up) non-vtec motors have knock sensors.
Your stock B18A ECU doesnt use knock sensing so you wouldnt have to plug anything to that green ting.
rey_da9
Sep 25, 2015 11:05 PM
B23-Vtec
Transmission & Drivetrain
Feb 4, 2011 11:50 AM
zero2hero
Dec 22, 2006 08:30 PM
