thrust washer
Old Aug 22, 2002 | 09:41 PM
deviant1's Avatar
Default thrust washer
what is a thrust washer and where does it go? do they need to be replaced when rebuilding an engine?
Old Sep 3, 2002 | 02:26 PM
deviant1's Avatar
Default Re: thrust washer (deviant1)
anyone?
Old Sep 3, 2002 | 03:18 PM
Mikey3000's Avatar
the thrust washer or thrust bearing sits against the bottom of the block and is squeezed between the block and one of the crankshafts counterweights. you might as well replace it when rebuilding the motor, it's cheap. i think there's usually only 2 of them. look at #3
http://www.hondaautomotiveparts.com/...NKSHAFT-PISTON
[Modified by Salvatore Leone, 7:21 PM 9/3/2002]
Old Sep 3, 2002 | 04:24 PM
earl's Avatar
Yes replace them. Everytime you let the clutch out it pushes on the crankshaft and the thrust wash takes the hit. They go around the #4 main bearing with the grooves facing toward the crank. (The groove is how it oils.) I think it's only about $6-8 for a pair from Honda.
ashb82
Apr 7, 2010 07:17 AM
SuckMyDOHC
Jun 15, 2008 11:29 AM
jordan2305
Mar 18, 2008 06:38 PM
jweller
Apr 1, 2005 07:02 AM
Quetzolcotl
Sep 3, 2003 09:27 AM
