brake lights?
Old Aug 21, 2002 | 06:35 PM
EGh22aEG's Avatar
Default brake lights?
my break lights are out. my regular back lights work but not the break lights. i looked for a fuse but there isnt one for the break lights unless its not labeled or something. anyway i changed the bulbs and that is not the problem does anyone have any other idea of what the problem might be?
Old Aug 22, 2002 | 08:45 AM
avividmemory's Avatar
Default Re: brake lights? (esp169)
the fuse could be in the engine compartment with those fuses...check there, i think my friend had a problem with that too on his ex...we were unaware there were two fuses compartments, we only thought to look under the dash...but there is also one under the hood
Old Aug 22, 2002 | 10:28 AM
hmonglonertim's Avatar
It's probably your brake light swicth. It's located right above your brake pedal. Depress the pedal all the way and there should be a switch that completes the circuit so the brake lights can come on. You may be able to readjust the switch. If not you'll have to replace it.
Old Aug 22, 2002 | 05:19 PM
EGh22aEG's Avatar
Default Re: brake lights? (hmonglonertim)
yea i know about the fuse box in the engine comparntment its not there thanks for helping though......the idea about the switch sounds right i am going to check tommorow when i can see thanks guys
Old Aug 25, 2002 | 01:28 PM
EGh22aEG's Avatar
ok i checked the switch on the break pedal and it appears to be ok but i am pretty sure it is the problem does anyone know a way to tell if it is bad?
JAYDmManny1331
Sep 16, 2009 10:43 PM
b16avtecinteg
Lighting
Jan 30, 2008 11:49 PM
ef90ls
Jun 9, 2007 12:37 PM
cpuff
Oct 23, 2006 12:33 PM
-Whitey-
Feb 24, 2003 01:16 PM
