B18C1+B16 head
Old Aug 23, 2002 | 07:01 PM
Dodger2940's Avatar
Default B18C1+B16 head
Has anyone done this? what kinda numbers am I looking at? Can some one share some info with me. Thanks
B18C-EJ1
Guest
Posts: n/a
Default Re: B18C1+B16 head (Dodger2940)
It's a poorboy ITR engine.
Compression is a bit low in stock form (9.8:1), but it's a good engine.
Old Aug 23, 2002 | 07:06 PM
Dodger2940's Avatar
Default Re: B18C1+B16 head (B18C-EJ1)
Would the B-16 pistons raise the compression or would ITR pistons be better?
Old Aug 23, 2002 | 07:57 PM
drvfast's Avatar
itr would would be better but i don't know what the cr will be
Old Aug 23, 2002 | 08:24 PM
Dodger2940's Avatar
Default Re: B18C1+B16 head (drvfast)
Thanks. Does anyone know if people have had problems with this set up.
Old Aug 24, 2002 | 02:25 AM
B18C-EJ1
Guest
Posts: n/a
It's a reliable engine. Yes, B16 pistons will raise compression. Here's a great link.
http://www.bojangs.com/calculator/
Old Aug 24, 2002 | 02:29 AM
poison's Avatar
Putting a P30 Head on a B18C will yield a .2 increase in the compression ratio and is a poor man's type r, but is very reliable (obviously)
If you do this, and with B16 Pistons I forgot the exact CR in the B18C block, but with ITR pistons, you basically have a retarded B18C5 -- unless of course if you get ITR cams, but then just go after CTR cams and get yourself a P&P job, then you have a sleeper and 'incorrectly coded' B18C5 you made
note -- sarcasm in this post, just to disclaim
Old Aug 24, 2002 | 08:12 AM
1 2 NV's Avatar
i think the actual compression ratio drops .4. call race engineering, they can type it in their computer in seconds. its not worth it, keep the C1 head.
Old Aug 24, 2002 | 09:28 AM
salbaje's Avatar
i'm doing the same thing dohc delsol block w/gsr head w/itr cams. i was told that ill be getting about 10:8 cr. Can someone verify??
Old Aug 24, 2002 | 09:53 AM
rainmanEK's Avatar
big strong guy
Default Re: B18C1+B16 head (salbaje)
del sol block? b16a3? with gsr head you should get around ~.2 more compression, i know you wont have around 10.8! good luck, eric
Old Aug 24, 2002 | 10:23 AM
Al Bundy's Avatar
Default Re: B18C1+B16 head (rainmanEK)
b18c1 block + b16 head = loss of compression. The b18c1 head has a smaller combustion chamber therefore increases compression. stock comprssion for b18c1 is 10:0:1, so with the b16 head, you lose cr
Old Aug 24, 2002 | 10:25 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: B18C1+B16 head (OBD1KNOBE)
Is there an echo in here???
Old Aug 24, 2002 | 11:52 AM
Dodger2940's Avatar
Thanks all I think I will pass on the block and just go another direction. How about CTR pistons and Skunk stage 1 cams?
Old Aug 24, 2002 | 05:27 PM
AzG35's Avatar
I have this combo, with PR3 pistons, the CR is 11.1:1
With CTR pistons its close to 12:1
Definately upgrade the pistons if you have it apart, its worth every penny you put into it.
Old Aug 25, 2002 | 12:10 PM
poison's Avatar
Default Re: B18C1+B16 head (AzSi22)
****, I stand corrected
jbrokos307
Sep 29, 2011 05:44 PM
o0o_tylor_o0o
Feb 27, 2009 08:40 PM
7rrivera7
Sep 17, 2003 09:58 AM
vspec12
Apr 10, 2002 04:33 PM
SoLoMaNder
Feb 27, 2002 01:11 PM
