power steering hose
Old Aug 20, 2002 | 10:51 AM
sleeepy's Avatar
Default power steering hose
is there any trick or things i should worry about before changing the power steering hose? i got a hole on it n its leaking and the dealer wants to charge me $120. so its pretty much taking out the clamps frm the old one and put the new ones in right?? thanks
Old Aug 20, 2002 | 09:53 PM
sleeepy's Avatar
Default Re: power steering hose (sleeepy)
dammit anyone??
Old Aug 20, 2002 | 09:58 PM
91f22's Avatar
that's about it when you are done don't forget to bleed the system....raise the front wheelsand turn the steering wheel from lock to lock about 20 times and all the air should be out then top it off to proper level, run and check for leaks
confused1919
Nov 18, 2012 07:36 PM
RSXMartin
Jun 13, 2005 02:20 PM
illicon2003
Mar 20, 2004 01:38 PM
