Help needed, regarding rust on cams
Old Aug 22, 2002 | 12:28 PM
JDMLudeH22's Avatar
Default Help needed, regarding rust on cams
Hi there,
Im new to posting on this board, thou the infomation I have gained off of here is great.
Ive got a slight problem
Ive got a H22a, that unfortunatly has been stored with the Rocker cover off,
On 2 of the lobes a slight surface rust has formed, not deep at all.
My question is, if I fire it up like this will any damage be done, ive cleaned it off as best I can, but i imagine it will wear dead smooth once the engine has run for a little while?
I should probably take the cams out, but I need this engine in by tomorow hopefully
Thanks for your help.
Old Aug 22, 2002 | 01:01 PM
Screaming Vtec's Avatar
Default Re: Help needed, regarding rust on cams (JDMLudeH22)
No opinions?
Old Aug 22, 2002 | 03:44 PM
tinkerbell's Avatar
Hi there,
Hi there yourself!
the damage is already done. i really dont know - but id expect that there would be minimal short term problems,
in hte long term it may be a bigger problem, because of increased wear on hte parts, but who knows!?!?!
maybe someone else...
t..
Old Aug 22, 2002 | 03:45 PM
Steve91's Avatar
I recommend you buy a product called Navel Jelly. Most autoparts stores sell it in the body repair isle. This stuff removes rust nicely.
Old Aug 22, 2002 | 03:53 PM
91f22's Avatar
cams are hardened to resist wear and they shouldn't have a problem i have found the best way to remove rust or and unwanted wear is to ue light emory cloth and cleaning solvent (parts washer)
Old Aug 23, 2002 | 07:05 AM
jetdriven's Avatar
Default Re: Help needed, regarding rust on cams (91f22)
clean up the cam lobe as much as possible. some pitting will remain but just drive the car a few thousand miles and mic the cam lobe. as long as it is in spec or nearly so youll be fine.
Old Aug 23, 2002 | 11:26 AM
CHEETAH's Avatar
Hi there,
get some 2000 grit sandpaper, wd40 or motor oil, give a few light passes wipe it down to see if they disappear.
greg
hood ride eg
11
May 11, 2012 05:54 AM
joeygsr12
17
Jan 7, 2010 07:07 PM
EG type GTR
Aug 3, 2006 10:48 PM
fastludeh22
May 16, 2002 01:17 PM
