Will I pass emissions with crower cams??????
Old Nov 29, 2002 | 11:27 PM
integraautox's Avatar
Default Will I pass emissions with crower cams??????
I have a 94 integra ls and before purchaisng my cam set up i want to make sure it is street legal in AZ. my set up on my car will be aem CAI, DC 4-2-1 header, crower 403 cams, skunk 2 cams gears, B&M fuel pressure regulator. So will I pass emissions
Old Nov 30, 2002 | 07:56 AM
non-VTEC's Avatar
Default Re: Will I pass emissions with crower cams?????? (integraautox)
if it's only a driving test then yes you should be able to pass as long as your fuel pressure and ignition timing are at or around stock.
if they have a idle emmisions test in your area you might have a slight problem passing that part with those cams...........i would recommend getting a apexi s-afc and leaning it out at idle 7-10%
the cams make you idle very rich........
Old Nov 30, 2002 | 10:41 AM
kb58's Avatar
Banned
Default Re: Will I pass emissions with crower cams?????? (non-VTEC)
I wouldn't volunteer to the shop that, "I put in non-legal cams."
fungus mungus
Jun 11, 2012 08:26 PM
generalfred
Oct 26, 2010 03:19 AM
hybridsol
May 22, 2009 04:53 PM
drSquish
Jun 20, 2006 12:11 PM
teefunk01
Apr 12, 2006 09:21 AM
