scored crank
Old Nov 27, 2002 | 10:38 AM
S13 slide's Avatar
Default scored crank
if a block has a scored crank on the #2 cyl, what would need to be replaced to get it running? any machine work involved? im thinking about picking up this block really cheap to build up. thanks
Old Nov 27, 2002 | 10:47 AM
Spade's Avatar
Default Re: scored crank (S13 slide)
new crank
Old Nov 27, 2002 | 10:49 AM
S13 slide's Avatar
Default Re: scored crank (Spade)
what about the bearings? just reuse the old ones? or get some acl? better safe than sorry right?
Old Nov 27, 2002 | 10:55 AM
gtpilot's Avatar
Replace the crank and the bearings - main and rods...you will have to get the correct bearings by looking a the numbers stamped n the rods and crank. So, there is no damage to the rod that spun the bearing? No discoloration?
kirk
Old Nov 27, 2002 | 11:03 AM
S13 slide's Avatar
Default Re: scored crank (gtpilot)
i always wondered how are acl bearings one size fits all? they showd a diagram or something but i couldnt understand it. thanks
Old Nov 27, 2002 | 02:53 PM
martini's Avatar
ha. I entered this thread thinking "so what does buying methamphetamine have ot do with hondas?"
Old Nov 27, 2002 | 02:56 PM
CivicEK.PDX's Avatar
Default Re: scored crank (martini)
haha. didnt even notice that till you said it.
Old Nov 27, 2002 | 03:30 PM
ejprimo's Avatar
Default Re: scored crank (CivicEK.PDX)
scored crank.
i thought your were talking about drugs, too. haha
Old Dec 2, 2002 | 03:05 PM
S13 slide's Avatar
Default Re: scored crank (ejprimo)
hehe i think i spelled scored wrong?
Old Dec 2, 2002 | 03:51 PM
chevyalltheway's Avatar
you can take the crank to a machine shop and see if they can grind the crank. if they can you need to get thicker bearings, rod or main where ever the the crank was scored.
Old Dec 2, 2002 | 05:47 PM
earl's Avatar
ACL bearings will work fine for your rebuild. If your crank is bad, you can have it reground and acl makes a special oversized bearing just for that
Old Dec 2, 2002 | 05:54 PM
Kamin's Avatar
Default Re: scored crank (earl)
it depends on how bad its scored/marked
if its not bad you can have it polished off at an engine builder shop for 100-200$ but if you can feel the mark with your finger you may need to replace the crank. its best to have a professional look at it and see what they reccomend.
t_can
Engine Machining & Assembly
27
Jun 27, 2017 10:23 AM
hatchet_honda
Nov 6, 2009 08:26 AM
ShortbusEK
Mar 7, 2008 01:29 PM
DanishR
Oct 7, 2007 07:41 PM
NetLogic
Dec 16, 2004 01:57 PM
