TB Suggestion
Old Nov 26, 2002 | 06:08 PM
Unsung's Avatar
Default TB Suggestion
Thinkin about gettin a new throttle body... what are you guys running and what do you recommend? I was thinkin' JG 70mm. This is for a B16.
Thanks,
Old Nov 26, 2002 | 08:19 PM
Kataku2K3's Avatar
Default Re: TB Suggestion (JDM B-Series)
A bigger throttle body is just like a bigger intake manifold.... it's not goin to do much on a stock motor.... I'm not sayin you motor is stock but it will do the best for you with high compression and big cams for all motor or under boost... If you have a relativly stock B16 right now a CTR intake cam would probably be the best upgrade... Likewise if you have some crazy internals or are boostin a lot that throttle body could do you some good.. Peace
Old Nov 26, 2002 | 09:24 PM
Unsung's Avatar
Default Re: TB Suggestion (JDMspecEG6)
Hey, Thanks for the advice. It's a mildly built B16, Intake, Intake Mani, JDM header, 2.5" exhaust, CTR cams, and a vafc... I don't want to do too much more to it, so I was thinkin callin it quits after a throttle body and FPR.
Old Nov 26, 2002 | 10:06 PM
Kataku2K3's Avatar
Yea that's good.... Sounds like you are basically set for awhile... When you want more torque later on down the line... Just build a CRVTEC or something... I'm not really into LS/CRVTEC's but they can make some good power... My friend's EK runs 12.60's all day long with full interior... Over you it basically has a Portflow head (with a CTR intake cam that you already have), RC 310cc injectors, the B20 block bored .50mm over, and JE 12.5:1 slugs... Have fun
406Honda
Jul 6, 2012 05:22 PM
CivSiClone_96
Jun 12, 2008 08:34 AM
prjctwhteg
19
Jul 14, 2007 07:33 AM
1baddturbosi
Feb 18, 2007 07:36 PM
DX1992EG
Jul 21, 2005 09:41 AM
