Got a P28 ECU for me????????
Old Nov 25, 2002 | 07:28 PM
phiberoptik's Avatar
Default Got a P28 ECU for me????????
Anyone willing to drop me a P28 for cheap??
*edit* need manual *edit*
dbfreestyle@yahoo.com
[Modified by phiberoptik, 4:55 AM 11/26/2002]
Old Nov 25, 2002 | 07:38 PM
lsvtecvx's Avatar
Default Re: Got a P28 ECU for me???????? (phiberoptik)
Got a auto for 80 bucks
Old Nov 26, 2002 | 01:28 AM
10K2HVN's Avatar
how much does a P28 go for anyways..
Old Nov 26, 2002 | 07:35 AM
SRT-WHORE's Avatar
Default Re: Got a P28 ECU for me???????? (10K2HVN)
Some people will sell you one for $250 while others might let it go for $100. The price varies on those because everyone wants it and the only place you are probably going to find a stock one is a junkyard.
Old Nov 26, 2002 | 11:32 AM
Junk yards want like 200 atleast... half of them want a core as a replacement plus 190 bucks or so.
Ridiculous!
Old Nov 26, 2002 | 12:42 PM
Katman's Avatar
Ridiculous!
well I have an option for you. If you can find an OBD1 non-vtec ecu with this board number:
I can reprogram it to SOHC or DOHC VTEC, stock or race specs. IM me if you're interested (my email is broken right now).
Old Nov 26, 2002 | 05:11 PM
tommyboy's Avatar
Go to cherry-auto.com I got one for
$100.
Old Nov 26, 2002 | 06:12 PM
TheShocker's Avatar
Default Re: Got a P28 ECU for me???????? (tommyboy)
I work at a salvage yard... I can get P28 ECU's for around $135 shipped COD...
-Seth
Old Nov 26, 2002 | 07:13 PM
b00stn's Avatar
Default Re: Got a P28 ECU for me???????? (balch104)
Newbie Q but what does the p28 ecu do? what kind of increases in hp?
The p28, p30, and other OBD1 ECUs can be swapped over to OBD2 vehicles with a wiring harness and a little work. This allows for modification of your ECU as the OBD2 ECUs are unchippable.
Old Nov 26, 2002 | 09:30 PM
Katman's Avatar
It's just an alternate ecu to use, once its reprogrammed, for a DOHC VTEC engine. They're easier to find/locate vs. a genuine DOHC VTEC ecu. The hp increase on a stock/unchipped P28 is actually losing HP, since the ecu is orginally made for a SOHC VTEC ecu....meaning it will run lean since its orginally designed for a smaller engine. Once chipped with a worthy DOHC VTEC program, the P28 will match or surpass that of a genuine stock DOHC VTEC ecu, but in contrast, if you use the same exact program on a genuine DOHC VTEC ecu & a P28 ecu, both will run exactly the same since they're both using the same program.
Confused yet ?
[Modified by Katman, 10:32 PM 11/26/2002]
nfieldzy12
Apr 12, 2012 12:48 AM
typexero
Dec 24, 2007 06:08 PM
shifty35
Sep 16, 2005 06:49 PM
