trying to pull codes but its not working
Old Nov 29, 2002 | 09:51 AM
VTEC-DA's Avatar
Default trying to pull codes but its not working
I am trying to pull the codes off my ECU but nothing is happening. The CEL is on but when I jump the blue connector, nothing happens. I have a 97 motor w/ OBD2-1 conversion and p28 ECU.
Old Nov 29, 2002 | 09:57 AM
dragonrcr's Avatar
Default Re: trying to pull codes but its not working (non-turbo2dr)
make sure you are jumping the right wire and not the ignition timing one
satan_srv's Avatar
Are you keeping the wire in there? Leave it in, then turn the key to the on position..
Old Nov 29, 2002 | 10:03 AM
VTEC-DA's Avatar
Default Re: trying to pull codes but its not working (satan_srv)
Yes, I am jumping the correct wire.
ANd yeah, I am leaving it in. I put it in with the ignition turned to off, then turn it to on, the CEL comes on but doesnt blink.
Old Nov 29, 2002 | 12:36 PM
Chiovnidca's Avatar
That means there are no codes stored.
Old Nov 29, 2002 | 12:47 PM
salbaje's Avatar
something might be wrong with your harness and or ecu
Old Nov 29, 2002 | 12:55 PM
Desslok's Avatar
Default Re: trying to pull codes but its not working (salbaje)
Check your backup fuse under the hood.
Old Nov 29, 2002 | 01:10 PM
Finest's Avatar
Default Re: trying to pull codes but its not working (Chiovnidca)
Uh, you have no codes. Lucky you.
Old Nov 29, 2002 | 01:20 PM
satan_srv's Avatar
Default Re: trying to pull codes but its not working (Prelude_RCR)
Just do it when the car is running and you have the code then.
Old Nov 29, 2002 | 01:27 PM
VTEC-DA's Avatar
I am doing it when the car is running also, and nothing happens. Could it be a bad harness and/or ECU? How would I check that? I had hondata 2b on the ECU, could that be what is messing up the ECU?
AbitAvenger
Mar 1, 2011 06:49 PM
mouab18c1
Engine Management and Tuning
35
Aug 31, 2010 05:31 AM
ntrider
15
May 29, 2005 01:53 AM
HamiltonRex
Nov 14, 2004 03:46 PM
TurboBumblBee
Sep 17, 2003 08:23 PM
