Oil pump ?
Old Nov 26, 2002 | 10:19 AM
DOHCarp's Avatar
Default Oil pump ?
How can you tell if your oil pump is bad, and does anyone have a tech on the removal and install. Thanks
Old Nov 26, 2002 | 10:42 AM
Spade's Avatar
Default Re: Oil pump ? (DOHCarp)
Haynes has an answer. You measure the clearance of the gear and the housing.
Old Nov 26, 2002 | 11:02 AM
BROOD's Avatar
Default Re: Oil pump ? (Spade)
Yep gerotor clearances should be checked and the pressure regulator assembly should be inspected as well. A good service manual will walk you through it; Haynes or Honda service manual.
stemcellsrock
Apr 29, 2019 06:24 PM
VaporTrail
Sep 5, 2006 03:35 PM
eghonda
Feb 7, 2004 06:03 PM
fastludeh22
Oct 28, 2002 03:17 PM
