VSS questions
Old Nov 28, 2002 | 06:10 PM
Kataku2K3's Avatar
Default VSS question
I'm putting a JDM GSR cluster into my friend's 88 CRX... I've got all the wiring figured out but i just need to know what the power, signal, and ground are on the electronic VSS... Here's a pic of the electonic VSS that i'll be using...
It's hard to see, but the connector release clip is on the top side so i can relate to the pins if we read them left to right knowing that the clip is on top... I've got a 5vdc power source for the VSS, so this is basically this is i have left to figure out... Thanks in advance... Latez
[Modified by JDMspecEG6, 7:11 PM 11/28/2002]
Old Nov 28, 2002 | 08:18 PM
tinkerbell's Avatar
Default Re: VSS question (JDMspecEG6)
dunno how you would hav found this by searching but here ti:
https://honda-tech.com/zerothread?id=340454
is this your answer?
hth,
t..
rigo1224
Jul 28, 2011 06:16 AM
solerizr
Mar 9, 2007 03:01 PM
eskimo_usd
Jun 9, 2006 03:04 AM
GSRCRXsi
31
Dec 5, 2004 09:45 PM
irtep
Dec 15, 2002 07:03 PM
