tick tick tick
Old Nov 29, 2002 | 11:55 PM
FitCRX's Avatar
Default tick tick tick
I have a ticking coming from top side of engine....comeing from between intake cam and injectors(in that area). I have adjusted the valves....what else would tick like valves? THe valve guides?
[Modified by FitCRX, 8:55 AM 11/30/2002]
Old Nov 30, 2002 | 12:32 AM
Nameless RB26's Avatar
Default Re: tick tick tick (FitCRX)
Is it a knock, or a tick?
I'm pretty sure the valves will do the ticking, and the piston/s would do the knocking. So you gotta decide for yourself. If you can hear it down below header area, it's probably the piston/s.
Have you tried an oil change?
Old Nov 30, 2002 | 03:41 AM
Ricky Rojales's Avatar
It probably your injectors. That's normal.
Old Nov 30, 2002 | 05:41 AM
4doorRS5spd's Avatar
New User
Default Re: tick tick tick (P)
Most of Honda's 4 cyl.'s do have a ticking sound to them, especially when cold. My Teg sometimes sounds like a sewing machine, and my Accord before that sounded much the same. I think these sounds are perfectly normal.
Old Nov 30, 2002 | 08:46 AM
Blaze45's Avatar
Brrraaaap!
Default Re: tick tick tick (4doorRS5spd)
What oil are you running? I ran 10-30 in my sisters Civic but when she needed an oil change I only had some 5-30 and it seem'd make a lil bit more noise, like the sound of oil thats really thin being slapped around. Its normal.
Blaze
Old Nov 30, 2002 | 09:12 AM
Desslok's Avatar
What he said
Old Nov 30, 2002 | 10:11 AM
FitCRX's Avatar
Default Re: tick tick tick (sp)
thanks...guys...I will continue to not worry about it.
Old Dec 1, 2002 | 03:01 PM
10K2HVN's Avatar
if it gets worst, its probably gonna be you valves (bent)...
Old Dec 1, 2002 | 03:46 PM
slow ride 74's Avatar
Default Re: tick tick tick (10K2HVN)
some times if you dont use a new gauge to adjust the valves your specs could be a hair off and no matter how many times you adjust the valves they will be ticking
trust me i worked on hondas over 10 years
theineffable
Honda Civic (2001 - 2005)
Aug 9, 2010 11:01 AM
roycivic92
11
Oct 9, 2009 06:16 PM
97BB6Type-SH
Nov 24, 2007 05:12 PM
do what
11
Oct 25, 2005 12:34 PM
twkdCD595
Jan 11, 2003 04:23 PM
