removing head bolts?
Old Nov 29, 2002 | 12:08 PM
SPEED123's Avatar
Default removing head bolts?
tried to remove the head fron the block but the bolts will not give. i even tried a breaker bar....no go! what else can i do? air tools? i don't want to break the bolts or else i would be screwed!
Old Nov 29, 2002 | 03:14 PM
Ricky Rojales's Avatar
Default Re: removing head bolts? (SPEED123)
Don't use air tools. You need to extended the breaker bar with a pipe. Use a smooth motion to rotate the bar. Make sure you loosen the bolts in the specific pattern shown in the Helm's manual in two steps. Otherwise, you'll warp the head.
Old Nov 29, 2002 | 06:28 PM
MachAF's Avatar
you should replace the bolts everytime you remove the head.
Old Nov 29, 2003 | 12:49 PM
prestonpark's Avatar
Default Re: removing head bolts? (MachAF)
i just tryed to remove my head yesterday and im stuck witht he head bolt man i just heard a crack then it wont budge to turn
Tong.Y
32
Feb 1, 2011 02:05 PM
nemesis25
Feb 25, 2008 07:30 PM
xiaogou
Apr 7, 2007 12:47 PM
JdM_RACeR07
Oct 19, 2006 12:43 PM
smashed4thgen
Oct 20, 2002 07:08 AM
