Its lowered now what about an alignment??
Old Nov 27, 2002 | 01:19 PM
Stroker
Guest
Posts: n/a
Default Its lowered now what about an alignment??
O.K. guys you have always been helpfull in here so again i ask some dumb questions, i lowered the civic, and i went looking around for an alignment kit. Wich one should i get?? Theyrange for 695 to 50 bucks help please. I dont have a big *** bank roll, but i can afford about 200 bucks, but do i need that much??? Thanks
Old Nov 27, 2002 | 01:25 PM
sleeprhatch's Avatar
Default Re: Its lowered now what about an alignment?? (stroker)
skunk2 upper a arms
Old Nov 27, 2002 | 01:26 PM
Default Re: Its lowered now what about an alignment?? (sleeprhatch)
and washer trick for the rears
Old Nov 27, 2002 | 02:47 PM
Tetsuwan Atomu's Avatar
def. skunk2 for front...lots of control and easy to adjust
Old Nov 27, 2002 | 05:02 PM
Doctor CorteZ's Avatar
how much is your car lowered.
TOE eats tires not camber if its a reasonable amount.
I run 1.6 neg in front , 1.2 in the rear and have ZERO wear issues.
Old Nov 27, 2002 | 05:30 PM
976's Avatar
976
New User
Default Re: Its lowered now what about an alignment?? (Doctor CorteZ)
Your stock control arms and camber might be able to support your drop. Unless it is slammed, then a kit will be needed. H&R have a simple inexpensive kit.
Camber however needs to be fixed or else you'll lose performance and traction like most people the drop their cars. The tires don't lay flat on the ground, resulting in less traction, therefore less performance - get what I mean.
for you. I love the people that want everything to work effently on their cars, best way to do it, not half assed.
[Modified by w00t!, 2:31 AM 11/28/2002]
Old Nov 28, 2002 | 04:30 PM
Stroker
Guest
Posts: n/a
Default Re: Its lowered now what about an alignment?? (w00t!)
so whts the washer trick, i ordered the skunk 2 upper control aems and they will be here on tues, but what is the washer trick, and yeah itspretty much slammed. tahanks guys. Ohh yeah, whats all of this toe stuff, i thought that only camber needed to be changed, any input would be great
Old Nov 29, 2002 | 04:27 AM
camber and toe will need to be corrected if its "slammed"
the washers go between the body of the car and the upper control arms in the rear.
it should make sense when you look at the suspension.
mish__
Suspension & Brakes
Sep 14, 2011 09:02 PM
ShagPower
Mar 3, 2007 11:38 AM
JeremyL
Apr 12, 2003 05:25 PM
9KRacer
10
Feb 1, 2003 11:38 AM
29psiHybrid
11
Jan 9, 2002 05:01 PM
