Distributor
Old Nov 28, 2002 | 08:13 AM
VTI_VTEC's Avatar
Default Distributor
Please could somebody tell me how to change the O- Ring washer behind the distributor on a UK eg9 civic vti( ba16a2).
cheer kenny
Old Nov 28, 2002 | 08:56 AM
mugenracer's Avatar
Default Re: Distributor (VTI_V-TECH)
#1 your really going to get flamed about your name (have you never looked at your valve cover, or do you promote cordless phones?)
#2. disconnect the negative battery terminal, mark a line across the top flange of the distributor, so that you can line it up exactly when putting it back on again, then undo the bolts around the distr. take it out carefully, and you will see the O ring where the distributor shaft(?) enters the head, remove it and clean around the hole, then stick in the new O ring, and pop the dustr. back on again, making sure you line it up with the mark you made on the top flange
Old Nov 28, 2002 | 02:07 PM
VTI_VTEC's Avatar
Default Re: Distributor (mugenracer)
thanks for the tip about the name (i know it was wrong )
so it is that easily to change the O-Ring washer
kenny
themiz816
Apr 28, 2013 07:16 PM
blacktibby07
11
Feb 5, 2011 03:12 PM
phelpsj2
Aug 20, 2009 01:37 PM
RA61825
Mar 12, 2006 02:26 PM
Deemeetree
Nov 24, 2004 11:30 AM
