baffling code 67
Old Nov 30, 2002 | 02:51 PM
S13 slide's Avatar
Default baffling code 67
hey, my friend got a code 67 in his 97 civic dx, we replaced the header and o2 sencors from another friends car thats known to be a good header/cat/02. and theres still a code 67. we tried to reset the ecu, and we also tried the tin foil trick, none worked. were positive its a code 67, check it numerous times. what other things could cause the code? a bad ecu? thanks
Old Nov 30, 2002 | 07:15 PM
Spartanic's Avatar
Default Re: baffling code 67 (S13 slide)
first find out what the Code 67 is. If you dont have the manual then search the net.
Old Nov 30, 2002 | 07:42 PM
S13 slide's Avatar
its catalyst system effiency below threshold
Old Nov 30, 2002 | 07:47 PM
Chiovnidca's Avatar
That code usually indicates a bad cat.
Old Dec 1, 2002 | 06:44 AM
MikeSarr_GSR's Avatar
Default Re: baffling code 67 (Chiovnidca)
It could also indicate a tired secondary O2 sensor
YaBoiTHiZZ
12
Mar 28, 2012 08:10 PM
btrim23
Mar 14, 2005 08:01 AM
GruvyTune
Nov 4, 2003 07:42 PM
B18C1 '96 Coupe
Jul 2, 2003 08:43 AM
