fuel pressure is too high
Old Nov 29, 2002 | 08:33 PM
HondaCutter's Avatar
Default fuel pressure is too high
I have a LS motor with drag turbo with the vortech fmu and a walboro 255 high pressure. I got a fuel pressure gauge today to check my pressure, cause I figured if it was high, it would explain some of the problems I'm having. I checked it and saw 56 PSI AT IDLE!!!! Which, of course, is too high. What would cause it to be this high at idle? And how can I lower it, I don't have an AFC or anything like that. So what should I do? Thanks
Old Nov 29, 2002 | 08:53 PM
CIVILGSR's Avatar
Default Re: fuel pressure is too high (HondaCutter)
what type of problems did you have
Old Nov 29, 2002 | 08:59 PM
Default Re: fuel pressure is too high (CIVILGSR)
well, my air/fuel is going crazy and sometimes reading .5 to 1.4 volts instead of 0 to 1 volts. So, I think the high fuel pressure is causing my EGTs to go up causing the o2 sensor to mess up. I know the o2 sensor is ok, because it's the second one I've been through.
Old Nov 29, 2002 | 10:10 PM
Mista Bone's Avatar
D Tranny Guru
http://www.theoldone.com/articles/regulator/
Old Nov 29, 2002 | 10:58 PM
Default Re: fuel pressure is too high (Mista Bone)
i checked that out, i'm gonna do that for now. In the future I'll buy an adjustable FPR. Is the B&M makes good enough?
Old Nov 30, 2002 | 01:01 AM
Mista Bone's Avatar
D Tranny Guru
even with a B&M you have to do the bypass mod. I could not go below 46 psi with the 255 HP pump and B&M FPR.
Old Nov 30, 2002 | 05:04 AM
really? Damn.
rdssk8rcs1
Oct 2, 2010 07:41 AM
sparkso
Feb 24, 2004 06:38 AM
HondaCutter
Nov 30, 2002 01:57 PM
IVANITR
May 6, 2002 07:16 PM
ludelvr
Mar 16, 2002 09:57 AM
