loss of powere at high RPM's
Old Nov 30, 2002 | 09:22 AM
hatemachine's Avatar
Default loss of powere at high RPM's
i have a 95 civic 2dr 1.5 DX. i had sparkplug 1 blow from the manifold and i had it rethreaded, well since then i had the timing readjusted to honda specs, and teh plugs and wires are all new. asl well as all the distributer parts. why when i hit all the high RPM's does the car sputter like im running out of gas? i have to ease off the gas for it to act normal. what could go wrong, i use chevron 93 octaine gas and gas filter is new. could this be my cat converter?
Old Nov 30, 2002 | 09:28 AM
LOwrestling2001's Avatar
Default Re: loss of powere at high RPM's (hatemachine)
aren't spark plugs in the head? not the manifold? is ur car stock?
Old Nov 30, 2002 | 10:05 AM
Default Re: loss of powere at high RPM's (LOwrestling2001)
yea there in the right place, and yes the car is all stock.
Old Nov 30, 2002 | 11:15 AM
Aron Parsons's Avatar
you had a sparkplug blow out of the engine? like it ripped the threads out? i wouldn't be running my engine hard if it did something of that sort.
to actually help you out though, make sure your fuel pressure is within specs (~35psi). you could double check your timing as well, i watch people get screwed by stupid service people all the time. also, you're wasting your money by running 93 octane on a stock engine. you can run regualr old 87 octane and you won't feel a difference (except in your wallet).
Old Dec 1, 2002 | 07:21 PM
Default Re: loss of powere at high RPM's (Aron Parsons)
yea i had the preasure checked along w/ the timing all the same time. and luckly to my surprise, the person i have checking it works at the dealership i got it from. though it is under the table. he is still a mechanic ASE cert. could it be the CAT converter?
Old Dec 1, 2002 | 07:57 PM
the DR.'s Avatar
what do you mean by this?
Old Dec 2, 2002 | 08:40 AM
Default Re: loss of powere at high RPM's (CIVICtypeS)
well it was not screwed in tight enough and shook loose, and the last 2 threats were stripped out when the pressure built up
masospaghetti
Feb 15, 2016 11:52 AM
NirVTEC
Jun 30, 2006 09:07 AM
civic_std
Jan 8, 2006 07:51 PM
shu4civ93
Feb 16, 2005 10:35 AM
TeGGY_LS
Feb 8, 2004 09:14 PM
