question for you tech guys need to know ASAP!
ok heres what happened, I was driving and I shifted from 1st to 2nd very fast and it went in like it always does with eaze! So I put my foot on the clutch pedal and pressed down and tried to shift into 3rd but the rev would just go up, like I was miss shifting but I could never get it into third I put my foot back on the clutch pedal and I notice its still on the floor and won't come up! I pull over and I lift the pedal up by hand and it stays up, but when pressed in it just smacks to the floor and stays there like a dumb ****! I forced it into 2nd gear to make it home and no its stuck in 2nd, but I can probably force it out of gear, My questions for your techs are did I blow my clutch or is it the slave cylinder! thanks I appreciate the feed back peace!
if your clutch isn't working, don't force it into gear, try and rev match and slide it in to be nicer to your tranny. pedal on floor sounds like your slave cylinder, or a leak in your clutch line.
I did rev match it in to get it in gear! No there isn't any noises coming from the clutch or the tranny from what I know of! there is just no pressure in the clutch pedal to come up!
see if theres any fluid in the resevoir.
I just put in a new motor and with no fluid it just stuck to the floor, filled it up and pumped the clutch a few times, and everything is normal now
Sounds like a hydraulic problem, as mentioned above-check your clutch master cylinder reservoir fluid level. You probably have a leaking clutch master cylinder, slave cylinder, or both.
old_school_dohcvtec
Oct 4, 2007 09:47 AM
