fuel pressure questions and emissions
my car:
90 DX HB
stock motor
MPFI conversion
91 SI ECU
I/H/E
gutted cat
so i failed emissions today, no surprise. anyways, all the results point to running too rich, so im planning on buying a B&M FPR system and an air/fuel gauge. my question is, whats the stock pressure so i can get a baseline, and also, whats the lowest PSI i can go without running too lean and damaging my motor. here in tucson we have to pass the idle AND loaded tests, so i need to be able to run a very lean mixture, but not so lean that the motor is jepardized(sp). oh and i just replaced my plugs, cap, rotor, wires, O2 snesor, fuel filter less than a month ago.
90 DX HB
stock motor
MPFI conversion
91 SI ECU
I/H/E
gutted cat
umm did you just feel like wasting your money? trying to smog with a guttet cat? umm tyr putting a new cat on and you will pass.
if you want to know the stock fuel presure you have to get a fuel presure gauge and measure it before you put on the B&M FPR.
To get a car to pass with a gutted cat is extremely difficult. If you are in California, be aware that the state has lowered cut points to the bone. The car has to be tuned perfectly !!! Without a four gas analyzer to check emissions, you will be going back time and again and failing.
i just went through emissions again with number 2 injector unplugged and i still failed, it helped CO but HC got worse. im probably just going to have to put a cat back in for testing.
disconnect one injector,itll lower the HC and CO.
[Modified by sp, 10:57 PM 11/27/2002]
WHAT????!!! If you unplug a an injector the car will misfire and get much worse! If your worried about HC and they don't test for NOX, just advance the timing until it starts pinging, usually 3-4 degrees advanced more than spec. BE careful though, the car will be running lean and you don't want to drive it fast or like ths very long because it can cause detonation. What are the numbers and the limits?
How will emissions get worse if you unplug an injector? You will be pumping more oxygen into the exhaust stream, but no fuel (HC) and no partially combusted fuel (CO). It will help. If you pulled a spark plug wire it would be a different story. But I don't endorse this approach (disconnected injector).
but on some cars it wont work,the ecu ends up making the other injectors dump more fuel in when it see its running too lean.Kinda like a safety thing so the exhaust doesnt get redhot and burn up the cat.
oh,and another thing,if the car is running really bad and the HC is way too high and you unplug an injector,its possible itll get it too around normal emissions level and not an overly lean condition where the o2 sensor would go full lean and dump more fuel in....just a thought.
